Ok, still new to owning a CTD, and learning more and more every day. I own an '01 2WD QC with only 56, 689 miles on it. I get the oil changed thru the dealership (who have been pretty good up until a few weeks ago. ) I noticed that I had oil 'wet' spots on my towing receiver and bottom of rear bumper. I learned along time ago via an S-10 that i owned that I should look at the rear 'pumpkin', and front seal of the differential. On the Dodge, it is ok and there are no wetspots anywhere on it. I looked at rear brakes, then started to look forward of that. transmission is ok, rear of engine was ok too. Oil Pan had to very small wetspots where it goes over the crossmember, but looked more like a 'dry' wetspot, rather than anything more serious. I then looked at the front of the motor and about had a heart attack! (Speaking relative to looking at the bottom front of the motor and pan... . ->) all oil pan bolts on the front had oil drops forming. Behind the crank pully was wet, 3 bolts back on each side of the oil pan, going from front to rear had oil drops. Container that holds 'slobber' tube was about as wet as it could get. Fan, and front face of motor was wet. Took it to dodge, they then informed me about the slobber tube, and the container, then told me that I needed to remind whoever was changing the oil that they have to check that container and empty it. At this time, I promptly informed THEM that they are the only ones who do maintenance on my truck! :-{}
They changed the oil, emptied the container, and told me that my 'leak' has been fixed. I have since cleaned the front of the motor, oil pan, etc. with a pressure washer. This weekend I went to LaPlace, La. and noticed oil residue in the same places, so I washed again before making the trip there and back. Upon return, I noticed that there is once again oil along the seal where the pan meets the block (see pic #8), as well as behind the crank pulley on a piece of metal that seems to bolt to the front of the motor (see pic # 9)
I have tightend the bolts that hold the oil pan to specs (all were a little loose), but I really do no think that the seal is bad. I think that the oil on seal on the front of the pan is coming from above, but have no clue where to look, not that i can really see in there. With less than 57,000 miles on it, I am really suprised to see an oil leak period, but being new to diesels, I had no idea that the CTD even had a 'slobber' tube
so i am wondering if I should even be alarmed by this. When I see oil, I panick. Differential fluid, transmission fluid, etc, I can handle with a few pills, but oil... ... ... . well, time to break out the defibulator (sp?). Any ideas and or suggestions would be greatly appreciated. It is going back to them in 2 days to diagnose the problem, and to also drain a little oil from the pan seeing that they have the oil level about 3/4 above the safe mark. I am wondering if I should take it to another dealership, but since I live in rural Mississippi, I really dont have a choice. I do hope that it is fixed prior to the bog in May... . only live an hour and a half away. Thanks.
The link to view the pics that I took is
http://myweb.cableone.net/cyauch/pics.htm
