After giving this a little more thought, I think you just have the misfortune of having a front seal that started leaking. Its rare, but it happens
Back again. Everything was fine; hadn't noticed any leaks/wetspots... ... ... ... UNTIL this past weekend. I went to the local car wash, sprayed it clean (thinking that maybe, just maybe the dealer left the mess after they replaced the front seal 3 weeks ago). I made a few runs to Jackson, MS and noticed that once again, oil is leaking. At least I think its oil. When looking at it, it has a greenish hue to it (which could be the dye they used to find the leak the first time). But when swabbed with a Q-tip, its blackish in color. I was thinking that maybe it is a cooling problem cause of the color. Using the pics at the following location:
http://myweb.cableone.net/cyauch/pics.htm
Pic # 9 is where the oil is forming at, but nothing else above that appears to be 'wet'. Also, in #8, oil is forming at the seal, and seems to be seeping (or collecting there) along both sides of where the pan meets the block, all the way back to the crossmember. In addition, there are wet spots on the front of the crossmember (facing forward), as well as drip marks on the front stab bar. It is going back to the local dealer on Monday, but I am looking for some insight as to what exactly may be going on. The truck as only 57,800 miles on it, and it seems to be getting worse with each passing week. Should I be calling Cummins directly, or keep going the hassle of going to the local Dodge dealer. Help please. Thanks.
