Hello all, today I installed the 3k spring kit in my 1997 12v auto. After searching previous posts I was unable to find a situation such as mine. I removed the first set of stock springs and reinstalled the 3k's. While doing so I noticed that the "spring and weight set" could be turned by pushing it with my fingers. I was able to do both sides of the springs without "barring" the motor over via the alternator. The truck idles a little higher although it does drop to around 750-800 in gear with the air on so ok there. Truck runs well and is a night and day difference from the stock gov springs. My issue is this, while driving if you rev the rpms up and let off the engine will "flare" up and the rpms will increase then back off to wherever the foot feed is.
I took the thing apart about five times and adjusted the springs several different ways. They are now at the "two clicks past the first one setting". Any insight would be helpful.
Gerald
Gerald
