I'll try to keep this short... Last Thursday night I was driving around Columbus, OH when I suddenly noticed what appeared to be smoke coming from behind my truck. I could see it coming from around the trailer I was pulling in the head lights of the car following me (my wife and mother-in-law). So my first thought was a brake had locked up or was running hot... as I began to look at my brake controller to see if it was stuck or something... I notice the red oil can on my tach!!!
A quick check of the oil pressure gauge confirms, NO OIL PRESSURE! YIKES. As quickly as I could I got it into neutral and shut down the engine. I would guess from the time I saw the smoke to shutdown to be maybe 10-15 seconds. I don't know when the oil light came on. I managed to get through traffic and over to the breakdown lane with no problems. Upon exiting the vehicle, we discovered the entire passenger side was covered with oil. And once I got under the hood, I found that one of my bypass filter lines (Amsoil Dual Remote system) had broken.
I was able to remove the adaptor plate and replace it with a FRAM filter and Rotella oil after a quick trip to walmart (complete with some arm twisting to let us in, since they were closing. )
So my question is this... what do you all think the damage would be? There is nothing too obvious at this point. So far all I have noticed is a little different sound when I shutdown the engine (almost like it doesn't have the same compression... ). But otherwise all seems good? Any suggestions on what to look for?
