Just for the record, as first hand knowledge goes, I was there, like 8-10' away from the bada$$ Mitchell truck at the 345' mark, with video rollin'. Unlike some of you guys, who seem to know it all from your computer chair, I did witness it, and will set the record straight.
Yes, the bell housing and pressure plate were in peices, however, the bolts that hold the clutch to the flywheel were sheared clean off, therefore IMO caused the rest the carnage to follow. The flywheel was in one peice, as was the clutch disks, the pressure plate guts were MIA as a result of the sheared bolts, however the pressure plate housing was in good shape, both the housing and the disks were hanging from the input shaft.
I'm sure the sheared bolts were grade 8's, do they make a grade 10 or 12? Or hell maybee they need to use 1/2" pressure plate bolts. Then somethin' else would be the weakest link. With the majior power of THAT truck, somthin' has to give occansionally. Some of you guys are so egar to place fault on someones product because it broke, if you even had a notion of what serious power that truck makes, its a wonder it stays togather at all.
I drove a truck with a Mitchell clutch in it, about 2 weeks ago, I loved it, and as some of you know, mine is on order, and I cant wait to have it, that is by far IMO the BEST PULLING CLUTCH MONEY CAN BUY!
The Mitchells dont post awhole lot, so I thought I'd clear the air in they're defense (as if they need my help, they're products speak for themselves). Some of you guys need to find somthin' else to do instead of bashin' every thread you can, you sound like a bunch of women, I can't belive that this thread is still going, when it's in direct violation of the rules. Aperently some guys are imune to the "rules".
Later, Rob
