You certainly improved the studs, I’m just not sure it was necessary and that might explain Yukon’s stance.
Half a lug but engagement is ok with you? It wouldn’t be for me either, that’s for sure.
Maybe I missed this before, but from this explanation it sounds like you were perfectly fine as only .015” wasn’t engaged. That’s not much considering how much you did have. I still agree with you that Yukon should’ve stepped up and explained this better. I wouldn’t have had a “warm fuzzy” seeing and thinking what you were either.The supplied Yukon studs are 2.325 under head length. The Spindle flange thickness is .467, the rotor thickness is .393 and my wheel
flange is .770 which totals 1.63 which left only .695 protruding from the wheel flange.
I applied some Dykem to on a lug nut and found the thread engagement to be about .670 which might be fine but I’m OCD on this stuff
and for the price of these free spin kits I thought it should be at least the total length of the lug nut.
