Finally have everything installed on the "01" that was on the old "99. " Finished installing the BD Exhaust Brake this weekend. Today when I took truck out on a 300 mile run I noticed that with the BD Exhaust Brake switch on and running with the Cruise Control ACTIVATED that the exhaust brake is activated. If I put a little pressure on the footfeed, the exhaust brake would de-activate. When I disengage the CC the exhaust brake operates normally. Did they change the Cruise Control setup from the "99s?" I've adjusted the switch by the footfeed several times and still operates the same. I'm a little confused, it looks like the footfeed can flop around when the CC is engaged.
Suggestions would be helpful.
"01" Forest Green QC/LB ETH/DEE,4x4, 3. 54LSD, VDO (boost, pyro) Westin SS Nerf Bars and Grill Gaurd, Delta tool box, K&N.
00 28' Jayco 5th Wheel, 86 "Classic 16" Alumacraft, 00 Honda Rancher
Towing with a slight "edge" on the competition!
