I think you are a bit confused on the newer trucks. Your boost fooler for the 96 is not the same as what you need to do here. The 24v trucks have two over boost preventers. One is the waste gate on the turbo and one is ECM controlled defueling. The bully dog box you got will take care of the ECM so what you need to worry about is the waste gate on the turbo. Look at the turbo and there should be a hose running from the back of the turbo to a little fitting right where the output to the intercooler is hooked up. The fitting you need to replace is the little elbow. You should be able to get one from Bullydog or another memeber, I gave my extra away already so I can not help.
