Engine/Transmission (1998.5 - 2002) 01 problem
Engine/Transmission (1994 - 1998) 47RE slamming into gear?
01 build date of 08 ,00
Truck no power very slow 62mph, wot
150 Fass pump
changed filters . removed fed line at the fuel filter under the hood ,turned pump on
good flow.
Have codes read out in odometer window
1693 0251 0252 0237 how would this decipher out.
Thank you
0251 is a mechnical failure in the vp 44. 0237 is map sensor reading low voltage. 0252 is ?? and 1693 lets you know there is code in the ecm or pcm. Have your mechanic check the vp44.
150 Fass pump
good flow.
Thank you
VP death code unfortunately. My truck ran for about 1. 5 years after throwing that code before the dead pedal got too annoying to handle. It went from one a month to several times aday.
J-
