VILLA;
Do you have gauges? like EGR---if so did you notice that the EGR temp went out of sight Immediately. I have had this same scenario but mine is a manual. It would cause it to have NO power at all until the butter fly would then open in the pipe. I have less mileage on mine than you do. Solution is replace the cylinder. The seals do ware out. The person I talked to said that the seals are non-replaceable. They tried to unscrew one to check it out, and broke the cylinder. If you have one use the lube oil they have for it. not just any lube.
