03 Alignment
Sept. 24-25 @ LACR, any 3rd gens going?
Two Leer 100 XQs on eBay
I have had my 04 4x4 back to the dealer 4 times with NO LUCK. Yesterday, I was having my sons Honda aligned and took the guy out to look at my truck. He said by the looks of the tires, something was wrong. He put my truck on the rack and said it was "15 ways from Christmas". ! He printed out the specs and gave me a copy. I went 2 blocks down the road to the dealer and asked how my truck could be so far out of line in less than a week and 100 miles. . The service Mgr looked at the sheet, paused, and then called the shop up the road and made an appointment to have my truck done. Well, today, I drove 150 miles and I must say it has NEVER since day one been such a joy to drive! It is dead on! I take my hands off the wheel and the truck stays in my lane! Hats off to Les Schwab Tire in Oregon! They fixed my truck! Also, Dodge took care of the bill!
Did they put it in specs with the previous article? If not what did they use. I assume your steering wheel was turned to the left whileing pulling to the right. Any more info would be great.
Thnx
Deed
Before my steering wheel was turned to the left and the truck pulled to the right. Now the wheel is centered and there is NO more pull at all! This drives as well as my 72 Chevy truck collection!
Is there anyway you can find out how they fixed the camber and caster since we have unadjustable ball joints?
Thanx
Deed04
SilverFox said:
Don't have a part number but the manufacturer is: STEMPH Automotive Industries, Inc. http://www.stempf.com/index.htm
Don't have the part number.
Before anyone gets excited about this let me tell the rest of the story. First the alignment is good and the new ball joint is greaseable BUT there is no seal to keep dirt, sand and water out. I took a look at mine today and saw grease around it and thought he greased it and broke the seal. I cleaned the grease off and there is no seal. Every ball joint I have ever seen has a seal, doesn't matter weather it's greaseable or not they should have a seal, IMO. It didn't cost me a penny to have this thing put on but when it wears out, I'll have to pay for the next one and that will be like the one that was there in the first place. If your truck doesn't pull too bad, maybe you should just get used to it. I was so used to mine pulling to the right that when I first got in it after the alignment I thought it pulled to the left. Took about 5 miles to get things settled down so I could go straight down the road. My hope is that D/C will come out with an adjustable ball joint for '04 and maybe it will fit the '03. By that time the one I have now will probably be worn out and I'll need a new one.
To resurrect this thread:::
My uppers are toast, 36k mi. Called Stempf and ordered a pair of adjustable uppers , part # 44297 for 03-05 for $88. 17 each plus ups. After reading this thread and this post in particular I asked and they verfied that all their ball joints come with zirks and grease boots and if someones were installed and did not have the boots on then the installer removed them.
They are due here 8-8 and we will see :)
LSteiner said:
Hey Guys,
Found this in another forum, (sorry can't remember which one), and made a copy of
it some weeks ago.
I think you will find it worth reading :)
begin:
In a previous posting written by ???? (don't remember), they were complaining about a shimmy in their
Ram 4x4 after striking bumps in the road.
I suggested that the front end alignment has either too little or too much caster, thus causing a caster
shimmy. He did not like my response and changed his concern from a "shimmy" to a "bounce" (big
difference), and insisted it was the shocks. Maybe it is, I haven't driven it. He also said the alignment
"checked out". Here's the problem:
Alignment programs (and service manuals I believe), give a wide acceptable range for front caster on
the 4x4 Rams. I believe the range is 2 degrees to 5 degrees (if that's not correct, it's pretty close). The
problem occurs when the alignment tech (independent or dealer) tells you that the measurements
"checked out fine", just because they were in this broad range of acceptance.
Caster readings that fall on either end of the scale are subject to caster shimmy, even though they are
"acceptable". I had to align some 30 trucks and attend a 9 hour "Dodge Ram Chassis Dynamics
Diagnostics" training session (fancy name, ehh?), before finding out that 3 degrees to 4 degrees is the
optimal caster setting for 4x4 Rams that eliminates caster shimmy.
Below I will post what specifications I set Ram trucks to. First I want to give a little more info on correct
Ram alignments so you can see if you had a job well done,
The eccentrics on the lower control arms ARE NOT for individual wheel caster adjustments (even though
our alignment machine says they are). The eccentric sleeves in the upper ball joints are for adjusting
individual camber and total cross caster (difference in caster between two front wheels). This is why
replacement eccentrics are positionable in eight different ways.
Once camber and cross caster are attained with the eccentrics, the lower control arm eccentrics are
then used to swing the caster readings into specifications. The two eccentrics must be swung in the
SAME direction in EQUAL amounts. If they are not, it will create a setback condition (one front wheel
further forward than the other).
FYI - Comparing between the two front wheels, caster will cause a pull to the smaller value and camber
will cause a pull to the larger value. A truck set up with caster pulling in one direction and camber
pulling in the other direction, can lead to a wandering truck; even though it is "in specifications"!!!!!!
If the eccentrics on the lower control arms of your truck are not pointing the same direction, the
alignment was done incorrectly and the axle was "twisted" or "forced" into position to attain the
acceptable values (seen them from the factory this way, go figure).
A correct alignment will set the truck up with a slight negative cross caster (truck has slight pull to left)
to compensate for right hand road crown. Camber will be equal side to side slightly on the negative
side. This will help maintain acceptable camber when hauling heavy loads, as the truck tends to lift in
the front when towing. Camber will then fall slightly positive when towing.
Just because the alignment shop says "it's in specifications", that does not mean it is set up for proper
performance and handling!!!!!!!!!
Specifications (my personal settings for every Ram I align): all specs below are in degrees.
Left Wheel Right Wheel
Caster 3. 2 3. 5
Cross Caster -. 3
Camber -. 10 -. 10
Cross Camber 0. 0
Toe - standard specs, (maybe a little out if you tow a lot, they will pull in as the front end lifts up).
Brent
ASE Certified
Gold Certified Chrysler tech
__________________
98. 5 24 valve auto, 4x4, QC, LB, EZ, 275's, DTT Rebuild by Fred Swanson, EGT, FP, Boost and trans gauges, BHAF
9 1/2ft 3500# slide in S&S Camper, Torque Lift tie downs, Rancho 9000's
end:
Don't want to bust anyones bubble but this post and the specs are 2nd gen :eek: So you may not want to use them on your 3rd gen truck ;)
Check out this thread for another solution.
https://www.turbodieselregister.com/forums/showthread.php?t=99102
Let us know!
I would love to have some adjustable ball joints.
Have an '05 and it runs straight- no problem. My '99 was delivered (by the pendejos in Long Beach) horribly out of alignment. Really like the new beast!
... John
Long Beach
Bought '05 in Faribault, MN
My 03 with 16000 tracks straight and always has. Have had other trucks with a "pull" problem even though the front alignment is ok. . every time a 4 wheel alignment fixed the problem. If the back end is trying to "drive" the truck off center it will pull.
Just my 2 cents FWIW
