Me Too, well sort of, Fred Swanson if your listening, it did it again with your EZ box on '3'.
Mine will die when starting, turn the key, it fires right up, then the RPM fluctuates high, then 500 RPM, then dies. There is never any issue with driveability or idle otherwise.
Take out the EZ and no trouble at all, put it in and the problem will return, just maybe not right away.
I wish I had time to check further, but I am checking anyway. The problem appears to be the EZ is causing the fuel pressure to appear too high at startup / low RPM, to which the ECM/Pump reduces pressure and then there is not enough rail pressure to run, when it returns there is a slight surge but the RPM is reduced and the engine stalls.
The troubling concern is that its not consistant, but definetely related to the EZ, and may only be on '3'. I'm going to go to '2' and '4' and check some more.
Rocket, yours also sounds like a filter too, mine has been changed twice now, didn't need it this time, but I changed it anyway.
