Incorrect installation will result Poor start ,erratic rail pressure and monetary lose of power,Once they are seated correctly they may come lose, but when they do generally the hard start is only when cold, now unplug the FCA when running then shut down, plug FCA back in and it will start. leave it sit for 5 minutes and you are back to hard start, this always determines injector Problem not tubes.
If tubes are removed or reused 5 or more times replace them ( they may become warped) otherwise I have never replace them after inspection UNLESS they have some type of imperfection(s) or have been known to be over TQ.
Yes, when cold, they will not seat correctly, If loose or installed incorrectly(cross tubes)... hard start, once warm ,the tolerance is minimal and it will start. By unplugging the FCA, you are allowing the engine to fire at maximum rail.
I agree, this could be 1 or more injector's leaking off pressure, but imo, more often than not, it is not the injector body or nozzle.
Another factor to contemplate, anytime corrosion is evident on the outside of the tube, this proves water contamination because of leaking tubes, and more than
2 torque sequences, tubes should be replaced(imo). Anybody who has torqued anything
5 times, knows this product has been stressed too far(imo).
Todd , I am continuing to disagree, as long as cross tubes are being dismissed as irrelevant!
