Should of been 15,000 not 150,000 sorry.
Bert&Holli said:Thanks for the info guys, and Mundgyver, thanks for posting your results. I'll use that for comparitive purposes on my next one. I plan on sticking with the Amsoil and OAI so I can get a trend. I do by the way, change oil and filter every time. I think maybe that my iron was high because of the 6k on the oil, 5k was towing heavy (10k). I'm not easy on the truck when towing either, my foot is in it pretty steady. I could be way off on my theory of the iron, but my next sample should tell me more as I'm not towing at all. Thanks again.
Mundgyver said:I wonder if there is a difference in how one pulls the sample. When I installed my Spinner II, I installed a port that allows me to take a sample while the engine is running and warmed up with full oil pressure, vice taking one with nothing flowing and having to draw out of the dip-stick tube or from the drain port on the pan.
My thinking was I wanted a sample that is under actual running and temp conditions to go to the lab vice a static one.
How many individuals pull samples in active or staticand I wonder what the over all averages would look like between the groups.
YOU do need to look at trends! IN other words, continue your used oil analysis on a regular basis (YOU decide how often) and see if there is any BIG changes in the analysis. Continue to use the same analysis lab. They will tell you if anything becomes out of line. Believe in them. If they say "no corrective action" it simply says everything is OK. They have nothing to gain in giving you a false report. NO TWO ENGINES WILL BE THE SAME when it comes to wear!Bert&Holli said:491 hours on engine, 25k miles, 6k on sampled oil, most of that towing 10k fiver. Here's the results:
Iron 108
Chromium 3
Lead 3
Copper 13
Tin 0
Aluminum 10
Nickel 0
Silver 3
Silicon 7
Boron 13
Sodium 3
Magnesium 20
Calcium 3493
Barium 0
Phosphorous 1398
Zinc 1699
Molybdenum 9
Titanium 0
Vanadium 0
Potassium 0
Fuel (% Vol) <1
Vis @ 100c 13. 96
Water (% Vol) 0
Soot/Solids (% Wt) 0. 5
Glycol Negative
TBN 6. 17
Oxid 12
Nitr 8
F-soot 0. 54
What does all this mean? Also, the report says no corrective action, suitable for continued use. What are the normal parameters? Oil is Amsoil HDD 15w40
