My truck is an 06, 4x4, automatic bone stock. About 2 weeks ago I noticed what appears to be a transmission leak from the bell housing area under the middle of the truck. overnight, the drip is about 2" wide and will run down the driveway about 18" or so. The fluid appears redish in color, but also there appears to be s clear type of lubricant with it.
I had the local transmission shop trouble shoot the problem & they determined that the "O" ring was leaking, but replaced that and the front seal, and changed the transmission filter and fluid and the transfer case fluid while they were there.
The problem is---it's doing the same thing, so obviously they didn't solve the problem with what they did. The shop is reputable and will have another go at it. Does anyone have any ideas what the problem is? Thanks to anyone with help.
Chipster
Chipster
