07 MEGA DUALLY 4x4
Air Conditioning line cuts self
BRAKE and ABS warning lights
Time for some tires on the 07 dually with 33000 miles on the stock tires,probable can make it to 40K but up here we can get a fair amount of snow/ice some days/-30C/-40Cbelow. I have been looking at the Goodyear Silent Armor in the stock size(235/80/17--31. 8inches tall,220. 00 a tire out the door,mounted/bal/road hazard/tax--- yadda yadda yadda )BUT -------what are you other dually drivers running in a bigger size and have had goodluck without the rears touching,preferable 33 inch. I don't want to have to change rims and i know my option are limited,just want to move up one size or inch,may have to use a small spacer on the rear. Just want to know if i have any other options in size----suggestions please and no tire brand wars:-{}:-{}:-{}:D:D:D DW THANKYOU
I stayed with the stock size (LT235/85R16) since they stopped making a 255/85R16 and the next taller tire is a 285/75R16 which is a lot wider and won't fit on a 6" rim anyway. I don't know why the 255s disappeared since lots of people like a tall skinny tire.
I just purchased some 255/80/17, that is a 33" tall tire. This is a MT so the tread is aggressive and was the only Tire in that size I could find. I should have them mounted by the end of the week and will give an update.
DW... .
Are the GoodYears OWL?. It's hard to fing a good quality BSW these days. I only run BSW as to get all six into the rotation.
Mac
Mac
You can technically mount 4 "front" tires and run OWL's and still rotate..... you will always rotate the front tires to the inner duals and the outside duals will always remain outside duals.
Greg
DW... .
Mac
I think they are OWL,also looking at BFG A/T in 285/70/17(32. 78 inch) tire and run some spacers. Apparently from reading on all the sites,some guy are running 265/70/17 without any spacers and there is plenty of room between the duals. I bought the spacers(2") but may or may not use them. I run the BFG on my 2001 3/4 ton and have about 35000 miles on them,probable get another 10/15000 more. DW
DWeiler-
I have been running BFG 265-70-17s Rugged Trail and have been real pleased with the tire performance and mileage. I also pull various trailers ranging in weight from 5k to 10k and have not had any issues with the tires rubbing the inner walls on the "duals". Note: I am running 65 PSI in the front and 50 PSI in the back which i think works the best for normal wear. I can tell you these tires are no taller than the stock 235's but they look a little better on my dually because I have a level kit in the front. Basically I needed something to fill the wheel-wells (spelling). ALSO NOTE: You will notice some of the different brands out there look a little wider than the others even though they are the same size..... which is due to the tire pattern. Pay close attention to this because they may touch when pulling. I have a few friends with the same size that have less space between the duals than I do. Good luck and let us know what you decide.
My . 02
Southbound
2"Spacers arrived today from "wheeladaptors.com" ,may run them or not,BFG's A/T in either 265's or 285 70/17 run the same price---just have to make a choice now which way i want to go. THANKS for the advice-------I have looked at most of the major tire brands out there and i seem to keep coming back to the BFG A/T"s,been running them on all my rides for 20+ years(usually get 50,000 miles out of a set with proper rotation),just wondering if there were anything better----might as well stick with what i know than take a chance on a "New Tire" brand. DW
