Should be no problem at all, my SPS 62/14 does pretty much the same, depending where thre TST box is set at. Once it comes up on boost, temps drop unless I 'm really working it.![]()
try dropping a gear and raising the revs. i get better mpg and lower temps towing in 5th at 2000-2200 rpm
But, thats only like 60 MPH!
One of the most over look area in modding is oil cooling,If your running 1200 constant you can bet your Post Turbo oil temp is 500 Plus... running temps with your mods 280/300. . Plus . $350. 00 for Plate & fin cooler with all the hose and hardware... oil coolers with Top Quality hoses and hardware will live for as long as the Truck.
My truck tow's best using the wild program on level #3. I started out on my last trip on moderate #3 and the egt's would peg the gauge at 1500. The first overnight stop I loaded the wild program #3. The next day I couldn't get the egt's over 1300, cruising at 70 plus the temps would average about 850.
I pull a 13k fifth wheel camper. My truck doesn't like the other softwares when towing for some reason. Hope this helps.
The only time I had to down shift to 5th gear was on a 7% grade that was about 5 miles long. That was the only time the temps got to 1350. Other than that the hills dont slow you down much at all.
The only thing I had to be careful with, was at about 2100 to 2200 rpm in 5th or 6th gear, if I gave it to much fuel to fast the stock clutch would slip.
I also gained about . 5 mpg on the wild program, hand calc'd.
