Engine/Transmission (1998.5 - 2002) 1-3 PSI upon Start/Turn of Key .....to 14-16PSI??
Engine/Transmission (1994 - 1998) Stupid KDP question
Engine/Transmission (1998.5 - 2002) No Gauges
Hello,
I am new to the forum and need some advice.
I have a 2002 3500 4x4 5. 9 with about 65,000 miles and have an Edge to basically monitor fuel pressure (as recommended on this site). Since last fall the truck starts hard when cold and smokes quite a bit. My previous fuel pressure would read at least 14 PSI +/- upon turning the key. However, now it reads 1-3 PSI at turn of the key. After turning the engine over it ramps up to 14-16 PSI.
Can I assume that fuel pressure is "leaking" out when the engine is shut down? If so, is there a particular place I should look?
Thank you in advance!
Joe
When you turn the key to on, it bumps the pump to purge it of air.
turn it to on, then just a little farther to bump the starter. It should run for 30 seconds or so. This will show normal fuel pressure.
Now the hard start, cycle the key off-on three times, read the codes in the odo window.
Thanks Fox!
I checked earlier today for codes and there are none.
Actually, the truck is getting rear brakes right now and I cannot try to bump the starter to see what the fuel pressuer is - as you specifed. I will do it early next week.
If I took a guess, the pressure would build to 14-16 psi. upon the starter turning. It's just that I do recall a time when the fuel pressure always held stable at 14-16 psi even during the process of turning the key to allow the glow plugs to warm (as an example).
Are there any particular areas that I can check to see if there is a fuel pressure leak once the truck is shut down and before re-start?
Thank you!
Joe
