'10 starter bit dust
Facory back-up camera
Cummins Newsletters via Email
Yep, the Amish around IN perform all sorts of skilled trade work in small shops. Their overhead costs and labor rates are low and their attention to detail very high.
Yep... I would trust a bench rebuilt starter way more than a brand new one that replaced a 2 year old one that failed...
In this day and age, a friggin starter motor should last 10 years or better...
Let me just say I have yet to replace a 3rd gen much less a 4th gen starter,and I work on them everyday. They are very reliable and much more durable than you think.
From what I can see all the 94 up diesel starters are 2,7 kw (3. 6hp)
Did a little digging last night before hitting the sheets,
5. 9 Starters are 2. 7kw as Bob has stated. The 6. 7 starters are 3. 0kw according to Delco Remy. They also have an "s" terminal on them now.
Delco Remy 5. 9 starter specs...
http://catalog.remyinc.com/Product/...e=39&model=1565&engine=5.9+Liter+L6+-+359+CID
New and Reman are available.
Delco Remy 6. 7 starter specs...
http://catalog.remyinc.com/Product/...e=39&model=1565&engine=6.7+Liter+L6+-+408+CID
Only Reman is available.
Mike.
from the 2012 fsm
STARTING SYSTEM
Starter Motor
Engine Application
3. 7L / 4. 7L Gas Powered
5. 7L Gas Powered
6. 7L Diesel Powered
Power Rating
1. 2 Kilowatt
1. 4 Kilowatt / 1. 9 Horsepower
2. 7 Kilowatt
* Cranking Amperage Draw Test
100 - 200 Amperes
125 - 250 Amperes
200 Ampers
* Test at operating temperature. Cold engine, tight (new) engine, or heavy oil will increase starter amperage draw.
from the 2007 fsm
STARTING SYSTEM
Starter Motor
Engine Application 3. 7L / 4. 7L Gas Powered 5. 7L Gas Powered 5. 9L Diesel 6. 7L Diesel
Power Rating 1. 2 Kilowatt 1. 4 Kilowatt / 1. 9 Horsepower 2. 7 Kilowatt / 3. 6 Horsepower 3. 5 Kilowatt
* Cranking Amperage Draw Test 100 - 200 Amperes 125 - 250 Amperes 450 - 700 Amperes 650 Amperes @ 8 volts @ 100 rpm
from the 2007 fsm
STARTING SYSTEM
Starter Motor
So it that saying the 5. 9 is 2. 7kw and 6. 7 is a 3. 5kw????
Mike.
No I think it is showing mistakes in the manuals,the early book still saying 6. 7 says 3. 5kw,The 12 book says 2. 7 for the 6. 7 and they wonder why I have trust issues... ... ... lol
Mike.
Mike,
What will you sell a 6. 7 Delco-Remy reman starter for?
I wonder if the OP actually needed a starter or if it was a mis-diagnosis? Was it actually changed and fixed the problem or still in the "I think" stage? There was not much info in the orginal post and no follow up post... .
Nick
Good questions. I've never had a starter failure in almost 700k miles. I don't remember reading of a starter failure here in TDR either.
Nick
Very likely scenario. There are so many causes for a no crank,with all the electronics now.
Those that have a high miles to start ratio may never see a starter issue,I have over 15 years on 94 starter.
