Engine/Transmission (1994 - 1998) 12 valve 174 hp with a p3000?
Engine/Transmission (1998.5 - 2002) Codes 1688 and 1689
i might be picking up a couple 12 valves with what is an inline pump which looks like a p7100 but is stamped -3000 it is cpl2063 and rated at 174hp. they are all reman engines from recon. are they any good? and can theese pumps be used in a dodge application? any info will be appreciated.
tag on the inj. pump is 3935787la m051005073b -3000
I am not sure, however the 3000 series fuel pump might be the Nippondenso? Again I am not sure but it seems like it was used in marine applications?
I did some research on the 2063 cpl, and it does come back to 174 hp at 2200 rpm with p3000 series pump, can't find application tho.
Nick
The p3000 was used on both auto and ind. engines auto on pre 1994 used the RQV-K gov. Ind used both govs. If you need to know more get me a part # and it is from Bosch
0402 066 703 is off of a 6CTAA cpl 1846 900ft lbs 280 hp 280 hp @2200 timing is 17 high idle-no load is 2473 CPL 2063 is part # 0402 066 707 and 0402 066 708 is off 6BTA 185 hp@2200 580 ft lbs@1500 13. 5 engine timing high idle no load 2457 and 2565 the 708 is 185 hp @2300 Hope this helps
it was 0402066709 i also have a 0402066707. they dont appear to have a fuel plate, does anyone have a diagram or pic of a cutaway? i would like to use theese in a few conversions without having to replace the pumps. if possible, and would like to turn them up a little.
