Engine/Transmission (1994 - 1998) 12 valve diagram please
was lookin for a diagram of the drivers side ,have a BAD oil leak in my new to me 12 valve its up high and to the left of the injector pump ... ... ..... tappet cover maybe??
thanks for the replies
If it is the tappet cover, which is very possible, be prepared to remove the injection pump. Just guessing, better part of a full days job.
The tappet cover is not labeled. It is the rectanular cover that goes from the rear of the engine and disappears behind the lift pump. Shown are 2 of the 6 or 7 bolts it has. High and behind the IP could be the cam timing pin has fallen out of the gear case.
