This isn't a clutch tread but to set the record strait... . Here goes I have driven two trucks with the DDD/Sachs brass pucked clutchs as well as my new South Bend. Both clutch chatter if you try and take off in 2nd idling. But my clutch seems to have more peddle pressure than both the DDD/Sachs. I have got used to the pressure and the reving to leave with mine. I am happy with my clutch but would be just as happy with the DDD/Sachs. As far as towing it does take alittle more ability but it can be done w/o any problems.
Joe your the man!!!!!! Where will it ever stop does Sickly have another 100 HP in it?
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11, 370 HP injectors, timing at 16 deg. , 16CM2 housing, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, Rad fan removed, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16, South Bend's Hypo Clutch*NRA/USPSA member and proud of it*
