12 volt power source from un-used dash connectors?
Shocks and steering damper replacement 2006 3500 4x4
battery fitment
Carling Contura II Series....the actuators are Western Star Truck but made by Carling...
Here is a little reading to get you started..https://www.carlingtech.com/sites/default/files/documents/V-Series-II-III_datasheet.pdf
They will snap in but are a whisker loose and can tip a little. That's why you see the Carling spacers in the unused holes. The center spacer had to be trimmed on the bandsaw a bit for a perfect fit...
Thank you MWilson, I will check that link out.
I too use an auxiliary fuse block in the passenger side dash access panel.
When I added a back up camera and heated driver's seat to my 04, I found a factory panel and mounted Carling switches. I'll eventually add a passenger heated seat as well, with one more open switch remaining.
