12cm2 Turbo installation on '93
Replacement downpipe?
Diesels run on hydrogenated french fry oil!
My 12cm2 turbo housing should be arriving soon. I heard that you must modify the downpipe for this installation. Is this true? Does anyone have any other tips for this installation? I would greatly appreciate it. Thanks.
Burkey
Mine: '93 250 LE 4x4 5spd 4:10 Pwr win/loc/mir,cruise,strait piped,12cm2 turbo,pyro/boost,diamond plate tool box, CB, 16x10" AR rims, 285/75/16 Bf goodrich, US Gear E-Brake,Fuller Roadranger shifter, PW injectors, K&N. "wirenut_21529" on Yahoo Messenger
Moms:'96 Ford B-Series school bus (5. 9 Cummins!)I'm gonna Bomb it!
Dads:'94 GMC 2500 6. 5L Turbo
Hi Wirenut.
You will have to modify the downpipe if you have the stock turbo on now. It needs to be shortened a little.
If you want a prefab'd unit, Banks' part number for the head pipe is 52118. But you need some way of getting the old one off (torch and impact chisel).
'93 W350 Club Cab, Bright White, 5 sp. , 130K, Factory Options: LE, 4. 10 Limited Slip, 7600 lb. rear springs, tachometer, front stabilizer bar. Mods: Banks stinger plus, Linex bedliner, 25,000 lb gooseneck ball, 10,000 lb receiver, Tekonsha brake controller, POWER WAGON injectors-WAY faster than stock!.
Thanks for confirming Mark! Isn't it flared on the end? I geuss I cant just take the 'ol porta-band saw to it. I wonder if there are any tricks to "rigging" it. Any suggestions? I got too much money in the 5" stacks I'm running to buy a downpipe. I think the shop I'm getting the stacks from sells that piece that connects to the turbo for big rigs. Maybe I can get a 3 inch one.
I would try to cut the pipe at the bottom where it hooks to the transfer case pipe instead of trying to re-flare the down pipe.
90 W250, 5-speed, isspro gauges, 16 cm2, K&N, Borgeson shaft
