How to get the turbo apart
Considering the stax......
Newbie Questions
OK- How in the %$&& do I get the housing off the rest of the turbo??? I have the whole unit sitting on my workbench. I am putting the 12cm2 housing on but I can't get the stock housing off. WHAT DO I DO???
Mine: '93 250 LE 4x4 5spd 4:10 Pwr win/loc/mir,cruise,dual 5" chrome stacks,12cm2 turbo,pyro/boost,diamond plate tool box, CB, 16x10" AR rims, 285/75/16 Bf goodrich, US Gear E-Brake,Fuller Roadranger shifter, PW injectors, K&N. "wirenut_21529" on Yahoo Messenger
Moms:'96 Ford B-Series school bus (5. 9 Cummins!)I'm gonna Bomb it!
Dads:'94 GMC 2500 6. 5L Turbo
wirenut, You'll have 4 bolts on the hotend side that go into the turbo housing. DO NOT HIT OR BEAT ON THE TURBO !!!!! Lots of oil such as Blaster. The fit is a very tight one even when new. I placed mine in a soft clad vise upside down and soaked the carp out of it with Blaster. Once it sit several hours, it started to release. I did put anti seze lube on the new unit as to help with future removal. Please do Not play around on the vanes either inlet or ehx. side. Too much $$$$ to replace. Mike
92 Std cab. LE. 215 P-pump reman cummins motor. 5-speed, 3. 54, 105 gal Aux tank in bed. Borgeson shaft, Banks Power pack. 12cm Hot end housing w/wastegate. 4" Exh, Pyro & boost guage, oil temp guage. E-brake. Galaxy DX99V, Used as a Hotshot/express Reg. at 36,000 lbs in 48 states. http://hometown. aol.com/hotshothauler/myhomepage/business.html 2000, 3500 being setup for Hotshot work as we speak. 250 miles todate
Oh He// not the hammer #ad
For future turbo housing removal guys: Use lots of penetrating oil now! Even if you are just thinking about a housing change! The best stuff I've found is a super sauce called: PEN Penetrating Oil made by State Chemical Maufacturing Co. 1 800 STA CHEM to order. One can gets me through about 20-25 turbos! DO NOT beat on the center section or the housing or the end of the exhaust wheels to get the housing off! Internal damage WILL occure if the end of the exhaust wheel is beat on! You might not even notice for a few hundred miles but the inner thrust bearing will be deformed and will wear VERY quickly. Be patient and let the pen. oil do it's job and it should come apart easily.
Owner: Stabco Repower. '89, CC, SB, 5sp, 3. 54, 16cm2 housing, maxed fuel, KN, Banks exh w/muffler, Horton fan clutch, Autometer liquid filled gauges, Factory tach option, 100% Dyna-Mat, Borgeson steering shaft, Firestone air bags, Chrysler V-twin air comp, 2. 5" lift, Rancho Shocks, Alcoa LTS wheels, BFG 255/85/R16 MTs (33. 3")
Uh... I didn't hit it too hard... I hope! It works. I just like tapped on around the outside of the housing in a circular motion as to not bind up the vanes on the inner wall of the housing. It should be okay. If not, I'll just order the HX40! #ad
