Engine/Transmission (1994 - 1998) 180 Vs 215 injectors
Engine/Transmission (1998.5 - 2002) P-Pump cam sensor
Engine/Transmission (1998.5 - 2002) 01 w/bad oil leak
FELLOW MAGNIIFICIENTS !!!
I'm trying to find out if there is any differnce between stock injector flow rates for the 215 HP P7100, as opposed to the 180 HP,. ( i,e. are they the same injector ????)
No. I believe the 180s have 5 holes and the 215s have 7 holes; I could be wrong on the 7; it's been a long time since I've looked at the 215s. All else the same, the 215s flow more fuel (produce more power). I've been running 215s in my '98 for 10-13 years with stock plate shoved forward. Engine finally chewed through the auto trans input shaft back in November. Been riding the motorbike since, waiting for the rebuild.
