19.5 Wheels
mud flaps
97 Factory Driving / Fog Lights
Want to replace my 16" stock wheels (rims) with 19. 5.
Are there any ford, Gm, or chrysler 19. 5 wheels
that can fit my 16" bolt pattern?
JimE.
the only 19. 5's that are a bolt are the Rickson wheels. They are custom made by rickson for ford and dodge trucks. www.dualdesignsinc.com makes adapters to the 10 bolt pattern so you can use std alcoa wheels. . much cooler looking and you can use 6 aluminum wheels instead of 4.
there's a company in houston that seel the same as dual designs. chromewheel.com i think
later,
mark
Thanks for the feedback Mark.
I use to have a 1978 Chey utillity truck that had 19. 5 Wheels.
I thought there mite be something old or new that will work.
A guy at the auto truck savage yard had this gauge that he
just put in the bolt hole pattern of the wheel and just went
around the yard matching up the wheels.
I will try him next.
JimE
Something to check, I recall someone saying that the 19. 5 wheels UPS used on there home delivery vans would work on our 1 tons.
I've never had the chance to check this out, but it would be great to find that they did, and find a source for good cheap wheels.
They might look pretty good after chrome plate and small dog dish hub caps were added, or just paint or powder coat and chrome lug nuts.
Ronnie
I hope you guys are rightbecause ricksonis convinced they're made of gold ;)
If I could find an OEM wheel I'd buy six and then beg for the $1200 for tires from the old ladi:D
STOCTON WHEEL WILL MAKE ANY SIZE WHEEL YOU WANT, I THINK THEY ARE @ $200. FOR SRW YOU SUPPLY THE WHEELS?. ,
AND $240. 00 FOR DUALLY YOU SUPPLY THE WHEELS?. I CAN'T REMEMBER IF YOU HAVE TO SUPPLY THE WHEELS OR NOT, ship these across the country and then back and it quickly becomes expensive. i am still looking at other options for 19. 5's. some day i will check with a local wheel builder when i get time and find a supply of 19. 5 wheels for a conversion.
scott4glamis,
do you have contact info for stocton wheel? cit, state, or ph#. . web site?
I'd like to give 'em a yell to see what they have to offer.
Thanks,
Mark
19.5 Follow up
Went to my friendly truck junk yard. (Petted the dog)
He said that " Dodge stand along with their wheels,
however dodge will fit chevy but chevy will not fit dodge,
do to the smaller center hole.
Will continue to look.
Note: He asked, " Don't Chrysler make those mail trucks?"
Hi guys, I realize this is a slightly old thread but I have done some research locally. There is a large tire dealer in my town that works with mostly large trucks and earth moving equipment. I spent some time there today with one of their reps. and I have a wheel coming from one of their other shop locations (in the next day or so) I hope. I am loking at this for a dual wheel setup. the wheel is 19. 5" X 6", 8 hole flat mount with a hub fit. The only question at this point is the center hole fit. The wheel book lists it as being the same as the Dodge. We will see. I have also checked some of the UPS trucks in town and the ones I have seen with duals are only 6 lug. I will keep this thread advised of what I find.
Sincerely, John
I called a wrecking yard and. . they said all the big three match on 8-lug bolt patterns.
there are problem w/16. 5" wheels the gm ones fit only gm because of an offset interfereing w/brake calipers. all the others fit gm gm just don't fit them.
he said the 19. 5s off a gm chassis should fit dodges.
