HI All,
I have a chance to buy an early 1991 W250 4x4 (no intercooler). The truck has 202K, a 5 sp and has a pretty good body and clean undercarriage. The previous owner put on a 4" exhaust (3" downpipe), BHAF, and Borgeson Steering shaft to replace the factory rag joint ... . The AC does not work and the vac pump is leaking a bit(engine oil),The truck is cooled by twin electric fans (old fan was not good because of a bad bearing and apparantly the shaft where the fan mounts is buggered up). The master cyl is leaking... . Owner says that he has not had to do anything to the truck... NO pump work or injector work... . It is an LE model truck with like new tires. The only other thing I can think of is that the clutch grabs off very close to the bottom... . can this be adjusted to grab a little higher up in the pedal movement or is this a sign of a worn clutch or other problem? Any idea what a reasonable price for this truck would be?... Anything else I should be looking for? The owner is asking $5000/OBO.
Thanks for any and all help in this.
Andrew
Andrew
