Hi,
I just purchased my first pickup, because it had my first diesel under the hood. The diesel makes a very sweet sound, I don't think I have heard such music before.
Come to find out, the front brakes are shot and the rotors are pretty badly gouged up. I have done a lot of brake work on cars, but the 8 bolt pattern on this truck is scaring me off a little. I have the factory manual, but it is still unclear to me what I am going to be dealing with. Do I need to purchase a 1-11/16 socket? Are the front wheel bearings inside the hub/rotor? When I reassemble the parts do I have to set front wheel bearing clearances? Is it advisable to replace the front wheel bearings as long as I have the hub removed? What is the gasket that the factory manual says should be replaced when I reassemble the hub? It look like the caliper is grabbing, since the outer pad is shot but the inner doesn't have much wear. How do I evaluate if the caliper is bad? I'm inclined to reassemble everything and keep an eye on pad wear. Is that a good idea? I haven't been able to find a step-by-step on replacing front rotors, like the step by step that is here for the KDP.
I am selling my 1971 911T to pay for this truck, so please someone have pity on this newbie.
1993 W250 169K
Springfield, VA
1993 W250 169K
Springfield, VA
