I bought some DFI 7x.009 sac injectors and new cummins connector tubes. Install went smooth or so I thought. Truck took about 2 minutes in total to start while bleeding lines and everything. It ran had rough idle because of air. Then it went away but a small rough idle stayed. I can feel the truck shaking and can hear it in the exhaust at idle. Then at 1000-1200 RPM the truck shakes more and the miss is louder. I can drive it and during accelration you can hear the miss very prominent in the exhaust. The truck does seem to run better but I do not trust driving it under the current circumstances. I loosened all the injectors lines at the head and the idle changed pitch and fuel spit out on all 6 injectors. I took the valve cover off and re-torqued the hold down and made sure they were all torqued correctly. The truck is still doing it so I know it has to be a problem with the injector itself or a connector tube if that's even possible. I checked all the old injectors and they all have copper washers
