1st gen owners...
Finally got some work done on my truck
Gutbag blues
... anyone out there tell me whether or not Dodge made single wheel one tons during this era? Just wondering. :confused:
From a technical standpoint I can't say for sure, but from a practical standpoint, the only real difference I've noticed between a 250 and a 350 (other than the number of wheels and the hubs) is one or two leafs in the spring pack and a badge. I'm 99. 9% sure the frames are identical. There may have been a heavier-duty D70 for the 350's.
- Max
Well I thought they made some.
I know the axle in mine is heavier that the normal 3/4 ton first gen... . the drums are heavier and all the brake parts were larger.
I assumed it was a one ton axle with 3/4 ton springs.
Yes they did. There's been plenty on here. Some members have them, seen them for sale on ebay, I guess park ranger/forest trucks, and phone company rigs came equipped this way.
A good friend of mine has a 1989 W350 with only four wheels from the factory, so yes they were available. They had a GVWR of 8900, and my 1990 W250 was rated for 8610. With only a 290 pound difference in payload it's no wonder Dodge didn't sell alot of them. His truck has a gas powered 360ci, so I can't tell you if any were made with the CTD. Also, I believe the rear brakes are larger than the W250 counterpart (. 25 inch wider).
Hope this helps.
I don't know about the diesel years, but my '83 crew cab shortbed 4x4 is a W350. Kinda wish it was a W250 cause the insurance would have been a whole lot cheaper. :{
We have a 93 W350 single wheel here at work so I went out and compared specs. Here's what I found.
According to the sticker in the drivers door jamb
... ... ... ... ... . My 91 W250... ... ... ..... work W350
F/GAWR... ... 4060lbs... ... ... ... ... ..... 4500lbs
R/GAWR... ... 6084lbs... ... ... ... ... ..... 6084lbs
GVWR... ... ... 8510lbs... ... ... ... ... ..... 8700lbs
Tires... ..... LT235/85r16D... ... ..... LT235/85r16E
According to the sticker on the inside of the hood
Rear brakes. . 12x2. 5... ... ... ... ... ... ... 12x2. 5
... ... ... ..... 4500lb front axle... ..... 4500lb front axle
Both trucks are standard cab with a Getrag and 205 t-case
As you can see, the only real differences are the tire load range, the numbers on the door jamb sticker and the fender emblems. Neither truck was equipped with factory overload springs.
Travis. .
edit; added dots for clarity
I had the E rated tires on mine when I got it.
I also had to buy every combination of brakes and drums and use what fit... which was the drums with the extruded cebters and the largest wheel cylinders and shoes.
None of which matched the listings for a D250.
But I drive around with an empty bed 99% of the time so who cares...
Jay
350 Differance
My 350 has single rear wheels 91 and I found out when changing axles that it had a D 70 from the factory much lighter duty than the dually. So when I changed the axle I put in the Dana 80 dually from a 95 with no problems. Seems I was overworking the 70 and developed some noise. R C Oo.
W-250 and W-350's single or dually Diesels, all had Dana 70 rear ends in the first gens.
I thought single rear wheel W-350 Diesels wre only made from 89-91. 5. Those are the only ones I've seen.
Kurt
Kurt
Negative, the one we have here at work is for sure a '93.
Travis. .
I almost traded Mom's 92 (back in the day) for a 93 W350 SRW. Think it had overloads. Reg cab, 3. 54 gears. Didnt get into the GVWRs or anything like that. Had a Getrag, but they were too proud of that 0 to start the odometer reading for my taste. Mine will have 300K by the end of the month, and it is getting so fewer and fewer parts are original. AFter a pump rebuild, I will cross the $6K mark for what I have in it. That includes BUYING it.
Daniel
My '92 is factory singles,4000lbs front,6084lbs rear,8700gross. No overloads. It came w/2. 5 width shoes on the rear,but we changed to 3" at the first brake job. My cousin,(he was first owner) didn't like the way it stopped. He bought it thru a truck broker. Telephone company or whoever ordered trucks,and his was tacked on.
