Others here will disagree, but my stock in-tank pump (long gone) would not satisfactorily push fuel though the stock filter and a 2 micron filter. I could pull the pressure down to 0 fairly easily. I'd recommend a better pump of a dual filter set up.
Who is GDP?
I'm guessing something Diesel Performance.
*** edit *** Nevermind, I found another post that said Glacier Diesel Power. If I'm wrong, please correct me.
the two bases are 4770 the water separator pre filter is 3374 the 2 micron filter is 3674.
Others here will disagree, but my stock in-tank pump (long gone) would not satisfactorily push fuel though the stock filter and a 2 micron filter. I could pull the pressure down to 0 fairly easily. I'd recommend a better pump for a dual filter set up.
I'll be the second to disagree. I have a total of 5 filters (20, 15, 5, 2 & 2 microns) and at WOT never saw under 4 PSI with the Smarty @ SW #6.
Whenever I think my filtration is crazy I think of you and feel better about being a bit excessive... thou lately this filter has been crossing my mind... .
Parker
Remind me again what filters you are running?
