The ISC with the CAPS injection pump uses a lift or transfer pump much similar to the one on ISB engines in 98.5 to 2002 Dodge Ram trucks. It's a Carter basically and it's installed on a "head" block with inlets and outlets. I believe the return fuel runs through this block too.
This pump differs from the ISB in that it only runs for 30 seconds upon key-on, start up. After that the pump quits and the injection pump takes care of the fuel pulling duties. I think the unit I'm dealing with (on a fire truck) is on it's way out or has already checked out. It doesn't sound like it's under a load while running. It does move a little fuel because it worked for filling the new filter not long ago. But it took a lot longer than normal. The ISC fired up then died due to air in the system. That's never happened in 14 years on this truck's annual filter change. We usually run the pump for a minute (2 key on cycles) and all is good.
There was a TSB from Cummins to replace the top cover (in this case the pump to "head" block) gasket on this pump which I did. But it didn't really help that I can tell.
Cummins used to sell the replacement pump/motor. But now only sells the pump/motor with a new block assembly. This increases the price $300 and adds about 2 hours to the job.
If you take the typical Carter pump ISB owners use, remove the three stud screws on top, remove the top plate...and plug both the inlet and outlet you have what I have. These Carter pumps were left with the typical inlet/outlet holes undrilled. The inlet outlet function is handled by the "head" block the pump attaches to. Fuel comes in the top of the pump and exits the top of the pump.
Anyone know the PSI of this application? I may try a Dodge replacement pump (same connection even) and just remove the top plate. I'd have to buy some metric plug bolts and sealing washers to take the place of the banjo fittings. But other than that I bet it would work. The Dodge pumps run at 15psi but I have no idea on the CAPS ISC engines. I bet 15psi wouldn't hurt anything here if it doesn't hurt the VP44. And 15psi is better than my 0 psi now.
