It all depends on how air locked you are. If the engine is running, you have the air out of the system. If you are severely air locked, I hot wire the transfer pump on, crack open the fuel filter outlet until I have good fuel, then the VP inlet, VP return, then I'll crack open the injectors that I can get to and bump the starter 4 or 5 times to roll the engine over (there will be LP pressure present at 1 injector every time the VP is rotated to that point of injection for that cylinder) and get fuel coming from the injection lines at the head (same procedure I use when I R&R a VP44 - except I hand roll the engine over).
For future reference, when you change the fuel filter, I crack open the fuel inlet side of the VP then bump the starter to cycle the lift pump, when all the air is done rushing and I have good fuel, I close up the VP inlet, then do one more then bump the starter again to make sure. Makes a mess, but the air is out. You learn where to place the oil pan underneath the axle.
