I recently competed a LOT of work to my 01 3500. Now, I can't get it to start. I cracked the banjo line and had fuel at the VP44, then cracked injector 3 & 4, fuel going everywhere. Closed everything up and crank...it'll catch but not run. Gauges showing 200 rpm and wait to start light works. I can faintly smell stuff burning off, but it's not staying running. I did have the VP out to do the tappet cover gasket, but I replaced the VP44 with the timing marks lined up and keyway in the right direction, etc. When I first got everything back together, the lift pump wasn't priming. Had no power at the harness connector, so I removed the extension section and plugged straight in to the LP. Started priming right away with key on. Do I need to crack more than two lines maybe, or bleed more? Fuel was pouring out of 3 & 4 and down the back of the block. Maybe there's more air in there though?
Is there any way a crank sensor or something is bad? I don't want to throw parts at it, but I'm having a hard time seeing what would cause this outside of fuel.
The only code I'm showing on the odometer is P1693, which I understand can't exist by itself. On the gauges, it shows P1693, then P done. Nothing in E. Nothing on my bidirectional code reader, either.
Did the following relevant to the engine:
-Head gasket/studs
-All other gaskets
-Valve adjust
-Front/rear main
-New Valair Clutch
-Head gasket/studs
-All other gaskets
-Valve adjust
-Front/rear main
-New Valair Clutch
