Joe,
I just tried and failed miserably... ...
I can find them using my link for my local dealer but no part number or size is called out. Looks like you are on your own.
It says to call dealer which I can't do for you today.
I made a few assumptions, looked up a 2001 Cherokee 4WD.
You need #5 and #6 right???
Mike.
No problem, just sitting here catching up on a ton of paperwork.
Looking something up is a good diversion for a minute or two.
I would be comfortable with a Grade 8 bolt if they are US, or a 10. 9 grade if metric. Factory ones probably are less than that anyways.
As long as there is no flat surface on them to engage the bushing to create an eccentric for caster settings, if so you are probably at the dealer's mercy.
Mike.
Joe,
Get me the last 8 of the VIN and I will call my local dealer to see what is up.
Could go to a kit or some other thing.
Glad to do it, and if they find something I will post the part numbers for you.
Mike.![]()
Mike the vin nums are 1L567117. Thank you so much.
