hello i have a pretty urgent problem with my 04. 5 common rail . out of the blue it started idling roughly and pooring white smoke out the exhuast. truck has 130 thousand miles on it its a 6 speed four wheel drive. it has an airdog 150 on it with to fresh filters. an edge juice programmer and cold air intake system . took and had injectors tested and 2 tested bad and the rest werent far behind. so got a whole brand new set of +50 horse injectors and still did not change a thing. so i pulled the injectors and ordered the adapter to check the compression on the isb
#1 370 psi
#2 470 psi
#3 475 psi
#4 470 psi
#5 460 psi
#6 100 psi
know I know theres something up with #6 but just dont want to go pulling the head for no good reason . also not sure why #1 would be 100 psi less then the rest. I was talkin to the guy that did my injectors and he seemed to think that if the tip was clog on the injector and the fuel was just kinda dripin out that it would pool on the dome of the piston and could burn a hole thru it or if it was sprayin to only one side of clyinder that it could burn down the skirt of the piston . I do some to have a good bit of blow by to tho. its enough to float the oil cap on the valve cover. just wanted some thoughts before I start tearing her down
#1 370 psi
#2 470 psi
#3 475 psi
#4 470 psi
#5 460 psi
#6 100 psi
