2006 Quad Cab,8' box, 4x4,Picked up new Nov. 23/06,24000 miles. BONE STOCK. On my way home from work yesterday I run out of fuel,or at least I thought I did. The truck started to stumble and sputter then quit. The gauge was on empty but I am sure there was still enough fuel to get me at least another 10 miles. Any way,I got 5 gal of fuel and the gauge came up between 1/8 and 1/4 of a tank. I then followed the starting procedure in the owners manual,Now here is were the fun starts. I wound the starter over a couple of times for 3-4 seconds then the 3rd time the truck fired,it emmidately revved up past a wide open throttle range that I never heard before even at truck and tractor pulls I never heard a truck scream like this. For some reason I thought the fuel pedal was stuck to the floor,I tapped the pedal,nothing changed,I then turned the ignition off and pulled the key out and the truck ran for another 3-4 seconds,I was just getting ready to jump out because I thought it was going to explode and I have worked around a lot of screamin diesels over the past 30 years in the crane industry and never heard anything like this . I didn't notice the tack. The white smoke was coming out of the exhaust like a wide open fire hose shooting in a strait line 15-20' from the side of the truck. Total run time of about 7-8 seconds. After this performance the truck would not start at all. Hauled the truck to the dealership and it showed an over rev code and a key code. After some tests and checks,no fuel pressure,they are now taking a pump off a new truck and putting it on mine. If this does get the truck running I am worried about what long term damage this extreme over rev might have caused.
Apperceiate any feed back,Thanks,Rob.
