2007 radio removal - need pics / instructions
2004 RAM 3500 Measurement Request
Multifunction Switch warranty extension
I need to pull my NAV (REC) radio but I don't have the 2007 service manual. Does anyone have some decent instructions / pics on how to do it? An assembly blow-up would be nice. My 2005 manual is of no help since the dash has changed :(
Thanks!
You have to remove the floor console and/or cupholder, then remove the two screws from under the radio/hvac bezel, and then pop the trim panel clips (trim stick, pry bar, grab and yank, etc). Then just remove the radio screws and pull it out.
Is the 06 the same as the 07?
According to the coastalEtech I talked to, there are two possible versions that look alike. You must have the rear camera capability on the radio and the only way to determin that, is to remove the REC radio and check the back for the video 3 pin plug on the upper right. Check my thread "Nav REC Lockout" for info.
