2008 fan clutch help
Shell Canada Yellow Covers on Bronze Unleaded Pumps...
First year Cali approved 6.7L that has best performance
CBari
My father-in-law bought a 2008 that had been wrecked and put it back together and has been driving and all seems well, but has had some AC issues that has led some local mechanics to tell him his fan clutch is out. Is there a way to verify that it is no codes have shown any issues with it.
Here is what led them to this conclusion. The truck had to have condenser replaced due to wreck. Thus also had a system recharge. Then the compressor crapped out, so it got new compressor and dryer and system flush again. Now the mechanic is saying fan clutch is bad cause the head pressure gets too high. If they place a shop fan in front of the condenser it doesn't get to high. AC blows cold going up and down the road, temp on the truck stay right at 200 all the time. Driving empty or loaded highway or town no difference.
Hate to drop money on a fan clutch if it isn't bad, but also don't want to ruin the compressor again either.
The real way is to have the scan tool. It tells you the fan RPM. You can try covering the radiator (don't turn on the A/C) with a fender cover or paper and go out and give it a good pull. When the temp comes up over about 220, pull off the cover and drive it at fairly high RPM and the fan should roar and temp comes down quickly. If it doesn't time for a fan. And get the OEM fan or it is a waste of money.
