2014 2500 rear air ride installed
transmission Fluid Line Leak - Less Than 2200 Miles on New Truck!
May madness 2014
here are some pics I took from doing the install. for those thinking of doing it, its not to bad. but have a helping hand. ended up taking the exhaust tailpipe and heat shield off to get clearance for the install, made it much easier.
So, the all important question, HOW DOES IT RIDE?
AH64ID, that's a Kelderman kit. They have several different options, self leveling, manual adjust, computerized self leveling with different height presets, even a key fob you can select your different heights from. I'm going with the latter. Will be very handy to just reach in your pocket and hit a button to bring the tail end down for loading stuff, not too mention how handy it is for hooking and unhooking trailers. I had the Firestone 4tec kit on my GMC with a switch just inside the tailgate to drop the rear air, very slick!
sorry for delay. the ride when empty is a little softer and smoother then with coils so their is an improvement. I had 2400lbs in the bed with the bags and it is really smooth. hardly feel a bump at all. so im very happy. im hoping to do the front late summer or fall. I have manual fast valves from littlelarrys.com. they are a nice setup and work good. I like control of the suspension. its all a matter of preference as to the control of the suspension. I prefer to have full control. some people don't wanna touch anything and just put a self leveling valve in. I am gonna say that I think the kelderman kits is a good quality well built kit. took me and brother about 3 hours to install it. and we weren't rushing or anything. but like I said. for the upper brackets your gonna needs a second set of hands to hold nuts/bolts/and bracket at same time. its a little tricky. I found you can wedge your hand on top of the frame member just enough to kinda hold the top nuts in place while the other person gets the bolt started.
