2nd Gen Non-Engine/Transmission 2014 Ram 1500 EcoDiesel
2nd Gen Non-Engine/Transmission Borgeson steering box swap
Engine/Transmission (1998.5 - 2002) Help with code
Your central axle disconnect is between the diff and the right wheel. When you spin the right front tire, you are only spinning the axle shaft up to the CAD. When you spin the left tire, you're turning the differential, driveshaft, and right side axle shaft between the differential and the CAD. And since there's a little drag in the driveshaft and transfer case, that also means the spider gears in the diff are also spinning and rotating the right side output of the diff backwards.
So yeah, you're normal.
Unless you've got a limited slip in the front end, the torque should follow the path of least resistance. Typically it's through the side gears, spider gears, and out the opposite side stub shaft, but it's not really something I'd be all that concerned about if the front shaft is spinning too.
How's your wheel bearing?
I read in a search that the wheel should easily do 1-2 revolutions, mine is no where near that, not sure if being a dually effects it
Are you saying that the hub stops/locks up if you try to rotate it? It should turn all day long if you continue to spin it.
Nick
Jack up one side and try spinning the wheel. If it doesn't spin, then the CAD is not fully disengaging. I've never heard of the 1-2 revolution test. If your hub rolls smooth and is not loose, it is good. Brake pads will always drag on the rotors a little.
Thanks for replies. I figured I was reading too much into it. Brakes don't smoke anymore, thankfully my pads and rotors are ok. My hubs seem ok, everything is tight. If I give the tire a push it won't quite make a full turn. When the caliper was dragging I couldn't hardly turn it. Changing calipers and hoses didn't turn brake/abs lights off, mechanic got updated scanner to check and clear them tonight hopefully
<i>TDR writer John Holmes has submitted his draft for the next issue of the Turbo Diesel Register (due out in early May).&nbsp; In that article, he talks about trying to order a new 1500 with the V-6, 3.0-liter VM Motari diesel engine.&nbsp; Thus far, he has not been successful in placing an order.</i></p><p class="MsoPlainText"><i>Is this bad news or good news?&nbsp; How about just news?&nbsp; The following press release from the Ram public relations staff provides an update.</i></p><p class="MsoPlainText"><i>The bottom line is that writer, Homes, and yours truly will be waiting until sometime in the future to order a truck.&nbsp; Supply and demand.&nbsp; Not to mention I want a price-conscious Tradesman-style package.<br/></i></p><p class="MsoPlainText"><i>Robert Patton, Editor</i></p>
2014 Ram 1500 EcoDiesel Orders Top More Than 8,000 Units in Three Days, Filling Initial Allocation
· Between the afternoon of February 7th and the morning of February 10th, Ram Truck received more than 8,000 Ram 1500 EcoDiesel orders, which quickly filled the initial allocation for the exclusive powertrain
· First round of Ram 1500 EcoDiesel orders account for more than 50 percent of the total order mix
· Special order rate nearly twice the corporate average – an all-time high
· Overwhelming response attributed to best-in-class 28 MPG with 9,200 lbs. of towing capacity and strong consumer demand for exclusive light-duty diesel
· Actual customer orders for the Ram 1500 EcoDiesel take priority over dealer stocking orders
On the heels of EPA’s certification of 28 MPG, Ram Truck opened the initial order allocation for the 2014 Ram 1500 EcoDiesel to receive a flood of orders from dealers across the nation. More than 8,000 trucks equipped with the fuel-sipping engine that packs 420 lb.-ft. of torque have been placed—just over 50 percent of the total mix. Even more surprising is the amount of orders already paid for by customers— twice the corporate average of sold customer orders on a truck that customers have yet to test drive.
“The Ram 1500 is the only half-ton truck available with a diesel, so we see this as incremental business by having the only truck that can offer best-in-class fuel economy of 28 MPG combined with 9,200 lbs. of towing capacity,” said Reid Bigland, President and CEO — Ram Truck Brand, Chrysler Group LLC. “It’s every truck manufacturer’s dream to have this kind of initial order demand for a product. Fuel economy is the No. 1 request of half-ton buyers and the Ram 1500 EcoDiesel delivers without compromising capability.”
The EcoDiesel-powered 2014 Ram 1500 has earned a 28-mpg rating from the U.S. Environmental Protection Agency (EPA), the best highway-cycle test result ever achieved by a full-size, half-ton pickup. It also exceeds the EPA highway rating for the top-ranked small pickup. The breakthrough results mean Ram keeps the half-ton fuel-economy record set last year by the 2013 Ram 1500. Equipped with a 3.6-liter Pentastar V-6 gasoline engine, the truck earned 25 mpg highway, a rating that stands for model-year 2014. The Ram 1500 now owns the half-ton pickup segment’s top two spots in the EPA’s 2014 highway fuel-economy rankings.
Production of the 2014 Ram 1500 EcoDiesel began in February with a group of specialized trucks in popular configurations. Normal processes place the initial build under quality review to assure every truck meets or exceeds targets. Shipping is expected in March, keeping the planned delivery within the first quarter of 2014.
Although Ram has reached its first planned order allocation numbers in three days, customers who special order the new truck will have priority in the build. Orders for dealer stocking will be filled once sold customer orders are filled. The next order allocation of Ram 1500 EcoDiesel trucks will open in early March.
Ram 1500
Ram 1500 - the most recognizable pickup on the road - delivers best-in-class fuel economy of 18 MPG city and 25 MPG highway with a truckload of pioneering, fuel-saving systems including a fuel efficient and powerful 3.6-liter V-6 engine and first-in-segment technologies: TorqueFlite eight-speed automatic transmission, stop-start system, thermal management system, pulse-width modulation and active aerodynamics, including grille shutters and air suspension. For 2014, the Ram 1500 offers a new, 3.0-liter EcoDiesel engine that delivers an outstanding combination of best-in-class fuel efficiency 28 miles per gallon (mpg) - unsurpassed torque and up to 9,200 pounds of towing capability.
About Ram Truck Brand
The Ram Truck brand continues to establish its own identity and clearly define its customer since its launch as a standalone vehicle brand. Creating a distinct brand for Ram trucks has allowed the brand to concentrate on how core customers use their trucks and what new features they'd like to see. Whether focusing on a family that uses its half-ton truck day in and day out, a hard-working Ram Heavy Duty owner or a business that depends on its commercial vehicles every day, Ram has the truck market covered.
The Ram Truck brand has the most innovative lineup of full-size trucks on the market. Ram Truck has emerged as a full-size truck leader by investing substantially in new products, infusing them with great looks, refined interiors, durable engines and features that further enhance their capabilities. Truck customers, from half-ton to commercial, have a demanding range of needs and require their vehicles to provide high levels of capability. Ram trucks are designed to deliver a total package.
