tony1461571
Is the payload the combined weight of people and any cargo.
Like this person driving an old vw bug had 4 of her really fat friends got in a wreck. She got sued for one day of bug sales for 3.5 million!..I am no DOT regulation expert, but I am familiar with OSHA and EPA regulations. When dealing with machinery/equipment (especially with OSHA) "manufacturer's recommendations" is above actual written regulations on the hierarchy of rules scale. I can't help but believe there is something similar within DOT (whether state or federal). But like many have said, likely won't become an issue when exceeded.....until there is an accident.
1401 means it is medium duty... Some Rams need a Cdl driver....My Dually has a GVWR of 14K but it actually weighs 15K when loaded but it's under front/rear axle ratings and also below combined tow at 32,500#.
Some will say I am "overloaded" but the fact is the 14K is just a number because if it was 14,001# it would fall into a different classification causing insurance and licensing financial woes. The F450 with pickup bed is rated at 14K for the same reasons.
The RAM website says your configured truck weighs 8,174 lbs.....5,003 lbs front axle & 3,171 lbs rear axle.Megacab is 8900!.... Old dually quad was 8000 .... Oh, when registering I claim 5999 lbs. this is because weight declaration is only for commercial and not private use...
Or.......the scales at your local dump S*U*C*K !!!Apparently , by adding fuel , a 32 lbs hitch, liner, running boards adds
726 lbs!����
I changed my GVW today, as when I transferred my old plate to my new truck, old plate was for a GVW of 8800 lbs
so to get it to what the OEM truck 10k GVW was, I had to raise it
was super simple, AAA girl filled out a form and charged me a few bucks to send the paperwork into my DOT, to do the change, and then I will now pay a few bucks a yr more for yearly reg due to higher weight deal
small no big deal.
I was told here in Nevada to not declare gvwr unless truck is used commercially. It is registered as a car..The forms were to raise the GVWR, not just the registered weight? What state?
Sounds easy, for you, the process is likely/possibly different in other states?
It's easy for me to raise my "declared" and registered weight in Nevada, but the GVWR sticker is another matter, which I've not studied.
Another reason that gvwr is a number that is largely ignored and irrelevant on these trucks. Stick within FAWR/RAWR and have fun.
SIZE, WEIGHT AND LOAD
General Restrictions and Exemptions; Permits
NRS 484D.600 Prohibited acts concerning size or weight of vehicle; special permit; emergencies; exceptions.
1. Except as otherwise provided in this section, a person shall not drive, move, stop or park any vehicle or combination of vehicles, and an owner shall not cause or knowingly permit any vehicle or combination of vehicles to be driven, moved, stopped or parked, on any highway if the vehicle or combination of vehicles exceeds in size or weight or gross loaded weight the maximum limitation specified by law for that size, weight and gross loaded weight unless the person or owner is authorized to drive, move, stop or park the vehicle or combination of vehicles by a special permit issued by the proper public authority.
Yes! You know what?? I'm not going to sweat it. Ram said tow rating is 16660 .. Trailer gvwr is 16000 Gcvwr is over 25000. I'll just go by this. No how, no way will I ever hit gvwr of fiver...better yet, upgrade rims and tires and use the mega cab dually ratings!
I'm pretty familiar with noncommercial driving laws and vehicle codes in Nevada, and often there is more than one law that might apply to a particular situation... after just a few minutes of digging, I found this code, which is the first in this section. Pretty sure an LE officer could cite someone for being overweight using this law, and others. Is it likely, nope. Do I care enough to worry because I'm over GVWR for the truck but well under my GAWR with my popup camper on the back? Nope.
I just don't get it!. When yhe truck is optioned with 69rfe, the tow capacity "increases" the weight of 180 lbs by having yhe lighter trans than the Aisin.. Now, explain this... By adding a heavier bed, axle, 2 more tires, the tow rating increases??? Just added additional weight to the same truck.. Now, if ram says the tow capacity on my truck is 16660 lbs., they know the hitch weight can be 25 percent of trailer weight... If you go over rawr, or gvwr , then the 16660 is a LIE! It's like saying all at once, yes you can tow that, but No you can't tow that...That is the maximum estimated tow rating. Which assumes 300lbs of people, 100lbs of options, and hitch weight. It's an advertising number. It is nearly impossible to hit based on many factors.
Ram also states payload and max trailer weight are mutually exclusive.. A comment most skip over.
This is the 3rd thread where you will be told to hit the scales to see if your too heavy on the rear axle. That is a limit, the magical tow number from Ram is not.
Scales are an accurate way to determine if you need to worry or not. Advertising brochures are not.
I think it would be impossible to get a ticket for mfgr GVWR based on that law. There would have to be an additional statue that makes mfgr GVWR a legally binding number, and I haven't found one and have done a bit of searching. Registration weight is legally binding thou.
If GVWR is that big of a concern then modify your door sticker ratings. It's perfectly legal under Federal Title 49 CFR 567.7. I have one since I exceed mfgr RAWR with my 19.5's. I also raised my GVWR while I was making the new one. I wouldn't have done it for GVWR alone.
