2018 2500 6.7 Cummins Fan Clutch
DPF Regeneration In Process and P242F code (Long)
Put Gas in my 6.7
Hi. I'm hearing an odd faint noise in the engine compartment kind of like a whistle. I grabbed one of the blades on my fan and pushed lightly toward the radiator, then pulled lightly toward the engine. There is slight movement of the fan on the shaft/clutch. Should there be any play in the fan at all? TIA
Should be no movement on the fan clutch or the shaft. Depend son where the movement is. If the clutch assembly is moving on the shaft then it is the clutch assembly worn. If the clutch assembly and the shaft move it is the support bearing, either worn or the mounting bolt has loosened.
