2019 Ram HD
[raw]<div style="max-width: 1024px; margin: auto; float: left;">[/raw]
G.R. Whale
Ram and Cummins have skipped the nickel-and-diming for the 2019 ratings war, going straight to 1,000 pound-feet and a top tow rating in excess of 35,000 pounds. There’s plenty of other stuff too, but you’re going to hear those numbers a lot.
The new 6.7-liter Cummins is built on a CGI (compacted graphite iron) block—lighter, stronger, quieter and proven. Bore and stroke are 4.21x4.88, the compression ratio on the standard output is 19.0:1 while the HO is 16.2:1 and virtually everything else is different: rotating parts, pistons, head with improved exhaust braking performance, injectors, high-pressure pump, entire air-handling system, turbo…and the display wasn’t marked but it sure looked like an EGR cooler top right side. There’s more aluminum where it makes sense—water pump housings, brackets, etc.—and it runs on a dual-core processor.
Standard output is 370 horsepower (at 2800 revs) and 850 lb-ft (@1700), the HO engine is 400 and 1,000 respectively (peak torque occurs 100 rpm higher than the SO engine), and Chassis Cab trucks will get the updated engine so expect an increase when that appears in Chicago next month. Those are the only ratings…there’s no manual gearbox rating because no manual is offered. Ram noted with an ever-declining percentage (less than 4% recently) and fiscal responsibility said don’t spend developing a new manual gearbox, though I’m sure Cummins has the ability to deliver a “de-rated” engine package that could match the current manual gearbox capacity.
Both the 68RFE and AS69RC have been lightly upgraded, much work around engine integration with the dual-core processor aimed at better drivability. Both these transmissions are diesel-only and run by column shifter; all gasoline HD trucks run the 6.4-liter and a ZF eight-speed automatic with the rotary shifter. Power Wagon still has a transfer-case lever on the floor, and the eight-speed gives it a crawl ratio of 50:1.
The Max Tow package returns and brings with it larger rear rotors, a 12-inch ring gear, bigger bearings and shafts, the latter requiring a larger bolt circle, so whether or not you get Max Tow every dually will have a different bolt pattern than SRW trucks. With Cummins power, only the MegaCab 4x4 2500 has a tow rating of less than eight tons.
Of course cooling is upgraded too, the radiator taller, 39 inches wide and the grille opening 30% larger. Despite the added cooling aero drag has dropped by eight percent, in big part from the airdam and active grille shutters (all engines).
Everything else underneath will look familiar but not identical. The new rails are fully boxed, crossmembers stouter, 63 ksi steel used for the gooseneck mount, axles and brake calipers larger, springs a bit further outboard, shocks are monotube frequency selective dampers (except Power Wagon’s Bilsteins) hydro C-pillar body mounts and active mass dampers from the 1500, exhaust hangars different, the basic claims being stronger, quieter, and more refined. If I didn’t hear “capability” once a minute I didn’t hear it at all.
Though it’s all been massaged suspension configurations parallel the current truck, with the full-air 2500 and auxiliary-air 3500 options.
Last year’s bed and cab structures get a new tailgate, bumpers, front clip and mirrors, but the mirror mounts remain the same. There are at least four styles of lights and grilles, at least seven new wheel designs and a factory bed step option. Those mirrors now offer cameras (for the aerial 360 image), LED rear facing spotlights and power convex sections on the towing units—linked to the driver memory system if you get it.
Those bodywork changes plus active grille shutters on every powertrain yield a claimed 8% aero improvement, with the bumper/airdam area getting credit for almost half that: the coefficient of drag on a 2WD Quad Cab short bed is 0.409, and, thanks to an aluminum hood, revised bumpers and some other changes the truck is 143 pounds lighter: A co-pilot without exceeding GVWR.
Inside, the cabin is virtually lifted from the 2019 1500 model, including the real leather, wood and metal trims, a unique key fob for Limited trim, and the 12-inch tablet screen to echo a pair of stacked 8.4s. The Ram comes with active noise cancellation on all drivelines and is said to be 10 dB quieter than the old one, all the better for sampling the 17-speaker, 750-watt optional Harman/Kardon sound system. Headrests are now four-way adjustable—though I missed checking the center rear, multiple type-C USB ports allow charging at least three phones at once, Uconnect supports Waze and Google maps, the Power Wagon has a forward camera for trail use, there’s trailering reverse guidance, a trailer-mount backup camera with independent 12-way connector and tire-pressure monitoring for up to 12 tires on four different trailers.
Ram attributed the early availability of uncamouflaged tester photos to three items: One, it helps build awareness and interest. Two, it saves thousands of dollars on camo. Three, it lead to more than one-million miles of real-world testing and loads. They also pointed out that Ram 3500 has the highest rated resale value, while an article I read en route names Ram 3500 reliability “well below average.” Damn statistics.
Expect 2019 HD Rams to roll into dealerships in April or May so you can find out yourself.
19 HD Ram-2.jpg 19 HD Longhorn cab.jpg 19 HD ex man.jpg 19 HD frt case.jpg 19 HD grl shttrs.jpg 19 Mega Ltd rr cab.jpg 19 HD 4_1k Cummins.jpg 19 HD CGI.jpg 19 HD chassis.jpg 19 HD DRW frt.jpg 19 HD DRW rr.jpg
[raw]</div>[/raw]
Those bodywork changes plus active grille shutters on every powertrain yield a claimed 8% aero improvement, with the bumper/airdam area getting credit for almost half that: the coefficient of drag on a 2WD Quad Cab short bed is 0.409, and, thanks to an aluminum head, revised bumpers and some other changes the truck is 143 pounds lighter: A co-pilot without exceeding GVWR.
I was spooked by this paragraph
Not that I'll be buying one but I would rather have seen Ram skip out on the hp wars and focus their time on gearing. A true MD 8 speed and the same hp/tq numbers would be better money spent IMO an already torque management heavy 1000 lb ft engine, whatever that means.
But that wouldn't make for as good as press. :confused:
"and Chassis Cab trucks will get the updated engine so expect an increase when that appears in Chicago next month."
It's possible but doubtful. For whatever reason, the industry standard appears to be in the 350hp/750tq range for this class of truck. I have not seen any HP wars in class 4-5, it kinda stays boring, :) As far as the trucks go, I expect some up grades.
Still keeping my fingers crossed for at least an 8 speed and no DEF when the 5th gens come out. Then I might upgrade, not so much with the 1,000 LB/FT...already TQ managed to death.
I know I am in the minority, but love driving my manual transmissions, likely will keep the Cummins trucks I have for a while.
I'll patiently wait on the 2020 with 8 speed auto and 19.5s. Great looking truck. I personally think this motor is tapped out. We'll see another motor in 2020.
I was looking at their website this morning and I have to say im a bit disappointed. Either they have not updated their website in a number of years or they are truly indoctrinated ala EPA....
In addition, diesel fuel sold for off-highway use should not be used in any Cummins turbo diesel engine. This is due to off-highway fuels not necessarily meeting the fuel cleanliness or lubricity requirements for on-highway fuel specifications. Use of such off-highway fuels can result in accelerated wear to fuel system components.
On a lighter note, hydraulic valve lash, no more overhead checks. I'm guessing this is Cummins push to a lighter grade oil for the 6.7.
I have a well equipped 2007.5 with Smarty and other upgrades and 1 year old Suncoast 68RFE. I have run every possible tune even the high HP/TQ ratings with no TQ management. If the upgrades that are implemented in 2019 to beef up the drivetrain/transmission has been done and most of TQ management is removed this truck/engine combination would move mountains. This new engine will outperform the transmission/drivetrain now if TQ is removed.
For sure it has Torque managment, anything else would kill that drivetrain immediately in the lower gears.
Check out the drivetrain of a class8, there one sees how it must be built to withstand the torque of the lower gears.
Pretty obvious.
I certainly did. You can get but so much out of a 6.7...
All but brand new!!.. Not by a long shot. The majority of the refinements were simply making stronger the materials and parts to handle the very little that they did to make more power. Now that many of the parts are stronger and hopefully more reliable the motor/drivetrain will hold up. I would bet that the biggest hurdle they had was controlling heat. Maybe a very few tweeks on this reorganized motor to reach the 6.7 capability. Dump the TQ management a little we will see the true potential.
