2019 Ram HD
[raw]<div style="max-width: 1024px; margin: auto; float: left;">[/raw]
G.R. Whale
Ram and Cummins have skipped the nickel-and-diming for the 2019 ratings war, going straight to 1,000 pound-feet and a top tow rating in excess of 35,000 pounds. There’s plenty of other stuff too, but you’re going to hear those numbers a lot.
The new 6.7-liter Cummins is built on a CGI (compacted graphite iron) block—lighter, stronger, quieter and proven. Bore and stroke are 4.21x4.88, the compression ratio on the standard output is 19.0:1 while the HO is 16.2:1 and virtually everything else is different: rotating parts, pistons, head with improved exhaust braking performance, injectors, high-pressure pump, entire air-handling system, turbo…and the display wasn’t marked but it sure looked like an EGR cooler top right side. There’s more aluminum where it makes sense—water pump housings, brackets, etc.—and it runs on a dual-core processor.
Standard output is 370 horsepower (at 2800 revs) and 850 lb-ft (@1700), the HO engine is 400 and 1,000 respectively (peak torque occurs 100 rpm higher than the SO engine), and Chassis Cab trucks will get the updated engine so expect an increase when that appears in Chicago next month. Those are the only ratings…there’s no manual gearbox rating because no manual is offered. Ram noted with an ever-declining percentage (less than 4% recently) and fiscal responsibility said don’t spend developing a new manual gearbox, though I’m sure Cummins has the ability to deliver a “de-rated” engine package that could match the current manual gearbox capacity.
Both the 68RFE and AS69RC have been lightly upgraded, much work around engine integration with the dual-core processor aimed at better drivability. Both these transmissions are diesel-only and run by column shifter; all gasoline HD trucks run the 6.4-liter and a ZF eight-speed automatic with the rotary shifter. Power Wagon still has a transfer-case lever on the floor, and the eight-speed gives it a crawl ratio of 50:1.
The Max Tow package returns and brings with it larger rear rotors, a 12-inch ring gear, bigger bearings and shafts, the latter requiring a larger bolt circle, so whether or not you get Max Tow every dually will have a different bolt pattern than SRW trucks. With Cummins power, only the MegaCab 4x4 2500 has a tow rating of less than eight tons.
Of course cooling is upgraded too, the radiator taller, 39 inches wide and the grille opening 30% larger. Despite the added cooling aero drag has dropped by eight percent, in big part from the airdam and active grille shutters (all engines).
Everything else underneath will look familiar but not identical. The new rails are fully boxed, crossmembers stouter, 63 ksi steel used for the gooseneck mount, axles and brake calipers larger, springs a bit further outboard, shocks are monotube frequency selective dampers (except Power Wagon’s Bilsteins) hydro C-pillar body mounts and active mass dampers from the 1500, exhaust hangars different, the basic claims being stronger, quieter, and more refined. If I didn’t hear “capability” once a minute I didn’t hear it at all.
Though it’s all been massaged suspension configurations parallel the current truck, with the full-air 2500 and auxiliary-air 3500 options.
Last year’s bed and cab structures get a new tailgate, bumpers, front clip and mirrors, but the mirror mounts remain the same. There are at least four styles of lights and grilles, at least seven new wheel designs and a factory bed step option. Those mirrors now offer cameras (for the aerial 360 image), LED rear facing spotlights and power convex sections on the towing units—linked to the driver memory system if you get it.
Those bodywork changes plus active grille shutters on every powertrain yield a claimed 8% aero improvement, with the bumper/airdam area getting credit for almost half that: the coefficient of drag on a 2WD Quad Cab short bed is 0.409, and, thanks to an aluminum hood, revised bumpers and some other changes the truck is 143 pounds lighter: A co-pilot without exceeding GVWR.
Inside, the cabin is virtually lifted from the 2019 1500 model, including the real leather, wood and metal trims, a unique key fob for Limited trim, and the 12-inch tablet screen to echo a pair of stacked 8.4s. The Ram comes with active noise cancellation on all drivelines and is said to be 10 dB quieter than the old one, all the better for sampling the 17-speaker, 750-watt optional Harman/Kardon sound system. Headrests are now four-way adjustable—though I missed checking the center rear, multiple type-C USB ports allow charging at least three phones at once, Uconnect supports Waze and Google maps, the Power Wagon has a forward camera for trail use, there’s trailering reverse guidance, a trailer-mount backup camera with independent 12-way connector and tire-pressure monitoring for up to 12 tires on four different trailers.
Ram attributed the early availability of uncamouflaged tester photos to three items: One, it helps build awareness and interest. Two, it saves thousands of dollars on camo. Three, it lead to more than one-million miles of real-world testing and loads. They also pointed out that Ram 3500 has the highest rated resale value, while an article I read en route names Ram 3500 reliability “well below average.” Damn statistics.
Expect 2019 HD Rams to roll into dealerships in April or May so you can find out yourself.
19 HD Ram-2.jpg 19 HD Longhorn cab.jpg 19 HD ex man.jpg 19 HD frt case.jpg 19 HD grl shttrs.jpg 19 Mega Ltd rr cab.jpg 19 HD 4_1k Cummins.jpg 19 HD CGI.jpg 19 HD chassis.jpg 19 HD DRW frt.jpg 19 HD DRW rr.jpg
[raw]</div>[/raw]
Yeah that makes sense.:D
As see mine, how long does it stay in first gear, even uphill maybe 30 yard until it shifts to second.
Even with a stomp on start that 5 second doesnt heavily load the converter with heat.
Sure it's nice to have a low 1 for some applications.
For me nowadays it looks more like the never ending battle of the big three, strongest engine, most payload, lowest first, highest overdrive and so on.
No one asks the question- is this really important, does it make sense?
o_O
I have been puzzling over the scissor gear in the cam drive on the new 6.7. I found the video below showing geartrain setup on an ISX, so apparently they have been using this for a while. I can't help but be skeptical when introducing a moving part simply to reduce gear rattle. I wonder what the longevity is?
A photo of the new 6.7. Not sure if the setup is different than the big motors:
o_O
or......is it worth the $$$$$! Probably not, but some just gotta have the newest, bestest. Think I-phone as an example. Who pays $1k for a phone? When I win the next lottery, I am putting my order in, just the same.....:rolleyes:o_O
Friends,
Many of us knew 5th gen was going to blow our socks off, yet, I for one, elected to by a 2017 5500 that had sat on the lot for a year, that I tracked for about 3 months. For me, it was about making a killer deal. I'm lifelong Mopar guy and since 2000, a Ram guy. I'm excited to see all these new advancements as it is exciting to own what I bought for what I bought it for.
Now, if some kamikaze should take out my 2017, I might be all over a 5th gen.
Cheers, Ron
o_O
Agreed. Many of us live vicariously thru those that actually NEED those specs, but in the long run most of us don't actually use our trucks for all they were designed for, eh. I'm reminded of the Banks ram air scoop, or their ram air aerodynamic intake horn; they are marginally effective above 80% throttle or so, but we who are poor chart & graph readers presume the benefits are available from the "get go"! Just an observation; without "marketing" I'd still be single instead of married to an angel! :)
