Engine/Transmission (1994 - 1998) 24V guy needs 12V help
2nd Gen Non-Engine/Transmission limited slip additive
Engine/Transmission (1998.5 - 2002) Transmission Oil Leak
A friend is looking to buy a 12V, '97's I think, and I volunteered to help. I know quite a bit about 24V's but only some about 12V's. So can you guys help with some of the things you would be looking for? I know about 53 blocks but I could use some help with anything you can spot externally. I'm on dial up here at home so I'll check back in a few. Thanks in advace.
Overlly Valved :-laf
Things to check
KDP been fixed? Steering wander? Has the pump been tweaked by some one who knew what they were doing? If it's an auto, what does the transmission fluid look like? Shifts smooth and solid? That's all that I can thing of. Ken Irwin
Thanks Ken, is there any way to tell about KDP externally? I think can assume there would be no evidence on the pump externally. Steering & transmission will check. Do pre 98's suffer same trackbar syndrome as 01's, steering box issues? I'm sure he's looking at an auto so I'll check that out.
Thank, keep 'em coming...
Same steering problems. As for the transmission, if theres over 100k on it, and it doesnt look like its been removed, I would suspect problems in the future, depending on how your friend drives, and if he plans to bomb it. You can check to see if the pump has been touched easily, by the flat-head screws holding the AFC housing down. (look rearward past the injector lines, on the top of the pump, to the rear of it). There will be 3 flat head screws and one break off screw that looks funny. If the bluke (blue-black) paint has been cracked from the screws, someone has been in there.
As for the KDP, same as above with the paint. If you can see broken paint on the timing case housing bolts, someone has been in there for something. Other possibility is the KDP jig, and there would be a phillips screw on the inner middle of the case, just slightly above the fan mount. The screw head would be facing out towards the passenger side, on a 45 degree angle. The PO may have wrote a message on the top of the case also.
The other thing I can tell ya to check for would be ball joints. If the truck has over 100k, they probably need changed. A 2x4 might not though. A good inspection of the brake rotors would be a good thing too, they possibly have never been off (like mine were, they were a bear to replace, but with a porto-power was easier)
Good luck
-j
Thanks guys, we found a showroom 95 with 126k. However, of all the trucks we looked at I didn't see any evidence of the KDP being killed. I told my friend that is the first thing he has to do, make that second, he has to join the TDR first.
