Testing the Trac-Rite differential while the vehicle is lifted and turning one wheel by hand, the opposite wheel will turn in the opposite direction. This is normal.
If the Trac-Rite assembly has an internal failure it will lock axles 100% side to side.
To test the Trac-Rite process, raise vehicle on appropriate lift , place into gear and accelerate quickly (hard launch). A second technician will witness both wheels turning at the same speed at the start of the acceleration.
Another test for Trac-Rite is to slowly drive vehicle in an open area and completely turn wheels to one direction and accelerate hard. . The vehicle will experience tire hop or shudder. This is a normal
Trac-Rite differentials do not require friction modifier and should be used only with SAE 75W-90 GL-5 synthetic fluid PN 05102232AA
