285-75-16 spare tire??
Stat Temp Question
HX-40 Turbo from Majestic not clocked!
Been running my 285s for a while now. Love em. But, on my way down to Nashville, TN this week. . got to thinking. What would happen if I got a flat? Having the rear anti-slip, its out of the question back there to install the smaller 245 spare. On front, wouldn't it have a hard pull to the side with the tire? Is it managable enough to drive until you can get the 285 fixed?
I've tried to install a 285 as a spare... didn't work very well. I don't know what to do.
98. 5' Emerald Green 24v 2500 Auto/3. 54 4x4 SB QC 285-75-16's on Alcoa's. Everything but leather. PIAA 1200's, AMSOIL dual filter relocation system, Smittybuilt Stainless Steel Nerfs, Rhino Liner(Junk), AMSOIL air filter.
You could put it in the bed, or get one of those "4 wheelers get the hell out of my way" front bumper mounts. I was considering this because I want to get the 40 gallon spare tire fuel tank.
Eric
BTW are your 285 75 16's load range-E ? I got 265's because they told me theyre the largest tire with the E rating??
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Michelin 265 75 16 lr-E. Boost and egt gauges but basicly stock except for a "properly adjusted" AFC. Cat in the garage. Uniden HR 2510, Texas Star 1200 amp. 63,000 Mi as of 1/27/01.
NRA life member. High power/IDPA.
Eric, you don't HAVE to get E-rated tires, not even if you are running at max gross weight all the time. You HAVE to get a tire rated for the weight. There are a lot of D-rated 285/75/16's out there that are rated to carry MORE weight safely than an E-rated 245 or 265. Look at the maximum rated weight capacity for the tires, if they are rated for the weight get them regardless of size or letter rating.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Everything but leather NRA Member Great Lakes TDR Member
Deezal Man:
I have the "B. F. Goodrich Radial All-
Terrain P285/75R/16 tires on my truck.
I also have a spare tire that size up
under the rear bumper area where the
stock spare goes. I had NO PROBLEM
putting it up there and it has been
there awhile.
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
No comments regarding running the two diff size tires on the front. I have the same problem. So far no flat. But what happens when it does. My current plan is to put the spare on the front, move the front to the rear, and drive slow to the nearest place to get it repaired.
Since the front end is an open diff, are there any problems with short distance, slow driving in this configuration. Seems like this cant be much different that those POS spares they are putting in cars. Or is it?
The problem I see with going to a large spare is it will interfere with the way the 4" BD is mounted. Considering the full turbo back in the future. Plan to correct this then.
1997 2500 4x4, CC, Auto, 3. 54 LSD, 68K, Everything inc Leather, K&N, 4" BD cat-back, otherwise stock, Isspro Gauges(3), 285/75/16 on Alcola's, RS9000's, DC Molded ASB Running Boards, Chrome Trim, Canopy, ProFlaps F&R, BedLiner, Aux. Lighting F&R, and tons more.
[This message has been edited by SlyBones (edited 04-05-2001). ]
Slybones, that is my plan too. Put the front on the back and put the spare on the front. Should be fine for a while.
Worst case scenero is a flat on one of the rears. Put a 285 from the front to replace the rear and put the 245 on the front and drive it.
Made in Mexico: 2001 Dodge Ram 2500 HD 4x4, Regular Cab ST, ETC, Auto, 4. 10 LSD, Camper Package, Trailer Package, 100% Stock.
My 285 75 16 fit where the spare would normaly go with no problem at all. Did you try a brand new tire? Mine was the best of the old ones that I took off so it would have lost a little on the diameter by the treads being worn out. Something to think about.
John McEachern
Fort St John B. C. Canada
1998 12v, 4X4, QC, auto w/tc switch, air, tilt, cruise, 3. 55 gears, TST #6, Isspro boost/pyro/transmission gauges, BD VB&TC, CC industries headache rack and rails, JVC KD-SX949 Cd player, forest green, Brigestone Dueler M/T's 285/75/16, Eagle 16x8 rims, K&N airfilter.
Deezal Man, I have a NEW BFG All-Terrain 285/75R16 spare mounted on an "extra" 16x8 M/T Alcoa Challenger wheel. Even with a Bestop tire cover installed on the spare it still fits (JUST barely) between the frame rails.
I did however, have to come up with a plan to provide adequate clearance between my (285) spare tire and my Mag-Hytec diff. cover. I modified my spare tire winch cable assembly and fabricated an offset mounting adapter plate for the spare... problem solved. Theft Protection?... I added a Mopar/McGard security lock as well as a "Nukeproof" cable lock... and then there's the alarm system. That should keep it from walking away in the night.
BTW, there is NO interefernce with the 285 spare and my Banks 4" diameter exhaust system.
I have never seen a 285/75R16 tire in load range E.
[This message has been edited by John (edited 04-06-2001). ]
No, my 285's are D rated. I did however compare the lbs rating on the factory "E" rated Goodyears. The "D" rated 285 Bridgestone carry a slightly higher lbs rating.
Maybe I did something wrong. but it seemed as if the 285 was rubbing against the exhaust pipe. I'll try it again.
Deezal man, I have the 285 Bridgestones as well, and I can't get it to fit in the normal spare tire area. Did yours fit?
1999 2500 4x4, auto, 3. 54 LSD, HD241, Quad cab SLT, Blk Sport Pkg, 16x8 Eagles, 285 Bridgestone AT, Bilsteins, 100% Amsoil, 80/100w lights, Valentine One, DTT TC/vb, Mag-Hytek trans pan, DD2's, DD TTPM, Isspro gauges.
1992 SC400
1978 Mooney 201 IFR
