Engine/Transmission (1998.5 - 2002) 291HP and 569ft-lbs ?
Engine/Transmission (1998.5 - 2002) Con OFE Failure
Got dyno today, was this good readings for what I have? was hoping for more. these are ground specs what is at flywheel? more but how to figure I don't know. Going to get new turbo in about a week then gonna dyno again to see how my money goes.
You should be closer to 350HP at the wheels I'd say.
I've got Jammer3's and they did:
320 without and electronics.
342 with Smarty only.
383 with Smarty and Big Hoss.
thanks for replys, I was thinking low too! what gives? think I may have problem? jammer 2's are to be 75hp and juice w attitude stated 40-125hp hell thats 200hp minus the truck!!
your truck may have started as low as 160! also some dynos are more accurate than others. did you pull in 4th or 5th? 4th=HP, 5th=tq
What type of dyno was it? A load or inertia dyno? Load dyno's IIRC will read lower than an inertia dyno. I dynoed my numbers with whats in my sig except with a stock turbo and a smarty... as well as in 6th gear.
That's not bad for the early model 24 valve engines. The one thing about the 98. 5 and 99 model trucks is that the power and torque numbers were at 235/460, where as 2000 came and the numbers bumped up to 250/505 from the factory. Check w/your local dealer (Cummins or Dodge)---there is a ecm that I bought that put my truck more in line with the 2000 up models. If there are any questions---I have a diablosport power puck on it and does fine, so no problems on stacking it. Give me later in the day and I will see if I can find the paperwork for the ecm to post a cpl # for the ecm.
I don't know what type dyno but I have shelled out some money to get extras and sure thought would have been better! I am kinda thinking buy newer model: most of my up grades will work on the models up to 2002
I'm pretty sure all 5 speed 24valve trucks were 235/460. It is only the 2001-2002 6 speeds that have 245/505. The automatic's had lower power ratings in the early 24valves
John
1998. 5-2000
ISB With Automatic Transmission
Peak Torque: 420 lb-ft (from 1600 to 2700 rpm)
Advertised Power: 215 hp @ 2700 rpm
ISB With Manual Transmission
Peak Torque: 460 LB-ft (from 1600 to 2700 rpm)
Advertised Power: 235 hp @ 2700 rpm
2001-2002
5 Speed Manual & AutomaticTransmission
Peak Torque 460 lb-ft (from 1600 to 2700 rpm)
Advertised Power 235 hp @ 2700 rpm
6 Speed Manual Transmission
Peak Torque 505 lb-ft (from 1600 to 2700 rpm)
Advertised Power 245 hp @ 2700 rpm
heres what I would do, get rid of the edge, get a quadzilla adrenaline, either get a hot rod vp44 or get one off a automatic trans truck, and get a turbo, that will get you close to 500hp
In January I ran 368hp/967ft-lbs. That was before the HTT62/12 or the new VP44. I won't be able to run again until June 14 for the new numbers. I really hope you don't have the problems I've been having trying to get out of the 300's.
